Manually configures port speed and duplex setting configuration on one or more ports on a switch.
| port_list | Specifies one or more ports or slots and ports. |
| medium | Specifies the medium as either copper or fiber. Note: This parameter applies to combo ports.. |
| speed | Specifies the port speed as either 10, 100, 1,000 (1 Gigabit), 2,500 (2.5 Gigabit), 5,000 (5 Gigabit), 10,000 (10 Gigabit), 25,000 (25 Gibabit), 40,000 (40 Gigabit), 50,000 (50 Gigabit), or 100,000 (100 Gigabit) Mbps ports. |
| duplex [half] | Specifies half duplex; transmitting and receiving data one direction at a time. |
| duplex [full] | Specifies full duplex; transmitting and receiving data at the same time. |
Auto on for 1G and 10G copper ports.
Auto off for 25G, 40G, 50G, and 100G ports.
You can manually configure the duplex setting and the speed on 10/100 and 10/100/1000 Mbps and fiber SFP gigabit Ethernet ports.
In certain interoperability situations, it is necessary to turn autonegotiation off on a fiber gigabit Ethernet port. Even though a gigabit Ethernet port runs only at full duplex and gigabit speeds, the command that turns off autonegotiation must still include the duplex setting.
Gigabit Ethernet ports support flow control only when autonegotiation is turned on. When autonegotiation is turned off, flow control is not supported. For more detailed information about flow control on Extreme Networks devices, see the Switch Engine v33.1.1 User Guide .
When configuring combination ports you can specify the medium as copper or fiber. If the medium is not specified for combination ports then the configuration is applied to the current primary medium. The current primary medium is displayed in the Media Primary column of the show ports configuration command output.
The keyword medium is used to select the configuration medium for combination ports. If the port_list contains any non-combination ports, the command is rejected.
When upgrading a switch running ExtremeXOS 12.3 or earlier software to ExtremeXOS 12.4 or later, saved configurations from combo ports (copper or fiber) are applied only to combo ports fiber medium. When downgrading from ExtremeXOS 12.4 or later to ExtremeXOS 12.3 or earlier, saved configurations from combo ports (copper or fiber) are silently ignored. Therefore, you need to reconfigure combo ports during such an upgrade or downgrade.
The following example turns autonegotiation off for port 2 with copper medium and a port speed of 100 Mbps at full duplex:
configure ports 2 medium copper auto off speed 100 duplex full
The medium parameter was added in ExtremeXOS 12.4.
